I have simple macro for loading layer properties files starting browsing from a certain folder.
That script used to work, but now using version 24.3 seems the browsing is not starting from the wanted folder.
The script is shown bellow:
<klayout-macro>
<description>Load Custom Layer properties</description>
<version/>
<category/>
<prolog/>
<epilog/>
<doc/>
<autorun>false</autorun>
<autorun-early>false</autorun-early>
<shortcut/>
<show-in-menu>true</show-in-menu>
<group-name/>
<menu-path>file_menu.load_layer_props</menu-path>
<interpreter>ruby</interpreter>
<dsl-interpreter-name/>
<text>module MyMacro
include RBA
file = RBA::FileDialog::ask_open_file_name(
"Select Layer Properties File",
"C:\\data\\klayout", # Enter your favorite folder here
"Layer Properties Files (*.lyp);;All Files (*)"
file && RBA::LayoutView::current.load_layer_props(file)
</text>
</klayout-macro>
What could be the reason that macro not to work properly any more?
tyanata
tyanata,
Weird - it works for me, when I paste all that XML in to a new text file and save as Something.lym, then restart KLayout and attempt to open a .lyp file.
I of course replaced
with
but indeed it starts from that folder for me.
David
Hi all,
I also can't confirm there is an issue with that function. Maybe "c:\data\klayout" does not exist on your system or it's not accessible?
