For example, I have some gds files, 1.gds, 2.gds, 3.gds...., I would like to use python/ruby script to open 1:0 of 1.gds, 2:0 of 2.gds and 3: 0, 4:0 of 3.gds in the same panel at a time, it is better I can change the layer description from 1:0 to, for example, "Target", any suggestion to doing so? Thanks a lot for you help
then edit the layer list using the functions from the layer list's context menu (delete, rename ..) and save the resulting layer properties to a .lyp file with File/Save layer properties.
Hi Frings,
what do you want to do exactly? Open it for viewing or manipulation?
There is a introduction into the scripting feature here: http://www.klayout.de/doc/programming/index.html. It's mainly for Ruby but there is a section about how to translate Ruby to Python.
I am new to Klayout and I would like to open multiple gds layers at a time for reviewing, I will check the materials first, thanks for the help.
Hi Frings,
I don't think you'll need scripting.
Just try
