Hi - Thanks you for this great piece of software. I am a relatively new user and have started to play around with the arraying capabilities of KLayout. After arraying a cell and then resolving the array, when I try to edit an array instance, I find that boxes have been converted into polygons and I cannot use the box editing capabilities of KLayout. Is there something I can do to retain the box property in an array?
Shriram
Shriram,
Sorry I can't reproduce that. Here's what I do:
I am using KL 0.23.4 on Win 8.
Can you tell me what you are doing differently to cause the box -> polygon conversion?
David
Hi Shiriam,
Maybe you can provide a screenshot (dropbox link or whatever platform you like)? A precise description of operations you perform is also helpful.
Thanks for your replies. I realized that the issue was not arising because of arraying and resolving, but rather because of saving the layout in DXF format. After re-opening the DXF file, the boxes become polygons. However, the issue does not arise in the GDS2 format.
Shriram
Ah, that explains it :-)
DXF is a good solution for exchanging data with AutoCAD + clones. But I'd not use it for keeping my design data. DXF does not support all use cases. If you want named layers you could consider using OASIS as the format for storing your files. This format is the one with the best support within KLayout. Next one is GDS and then there is CIF and DXF (in that order).
