When I load a gds file to reivew:
mw = app.main_window
mw.create_layout(0)
gdsfile = "/home/test.gds"
view = mw.current_view
view.load_layout( "#{gdsfile}", true )
if will load ALL the layers into current view, so how to specify the layer:datatype when loading the gds file? For example, I only need to layer the 1:0 layer, or the last layer (does not konw the layer:datatype in advanced)
How to add option in load_layout to specify the layer:datatype? Thanks.
lm.map("2/1: Target",0)
when load_layout with this layermap, not only 2:1 but all the other layers will be loaded, is there any solution to load only the specified layer? thanks
Hi Wing,
can you paste the complete code, please?
