When I'm trying to invoke the read(some_file) on an RBA::Layout, does klayout also check the paths in KLAYOUT_PATH?
I am trying to write a generic script where I can give it just the base filename, and then have klayout check a list of paths until it finds the file.
I have tried adding the list of paths to KLAYOUT_PATH, but klayout does not seem able to find my file...
KLAYOUT_PATH is just used to identify libraries, load scripts and locate Ruby/Python modules. It does not change the behaviour of
RBA::Layout#read
.Like with every well-mannered method there is no hidden functionality within
RBA::Layout#read
. This method just takes the path as it is.But you can easily code the desired behaviour by running a loop over all the places you look for and employ one of Ruby's nice File module methods to check whether the file is there or not.
