I am having difficulties adding a PCell to a certain DataType layer. I can add it to the right layer but not to a certain DataType. It will always add it to DataType zero. I am trying to add a text(serial number) using a PCell to layer 45 and datatype 45 and the script will always add it to 45/0.
This is the line i am using to assign layer and data type.
param = { "text" => $SN, "layer" => RBA::LayerInfo::new($layer.to_i, $dataType.to_i), "mag" => $magnification.to_i, "inverse"=> invertedBool }
Here is the full code
module MyMacro
# 1. Open command line in directory "C:\Program Files\KLayout (64bit)\klayout_app.exe"
# 2. Run command: klayout_app.exe -b -r C:\TEMP\hello\addSerialNumber.lym -rd inputFile=C:\TEMP\hello\700-2000-00Ctemp.gds -rd outputFile=C:\TEMP\hello\my_layout3.gds -rd mirror=TRUE -rd rotation=23 -rd X=-6000 -rd Y=8000 -rd layer=9 -rd dataType=210 -rd SN=55AB -rd magnification=600 -rd inverseText=TRUE
include RBA
ly = RBA::Layout::new
ly.read($inputFile)
# create new cell TOP
#cell_index = ly.add_cell($SN)
cell = ly.cell(ly.top_cell.cell_index)
# Find the lib
lib = RBA::Library.library_by_name("Basic")
lib || raise("Unknown lib 'Basic'")
# Find the pcell
pcell_decl = lib.layout.pcell_declaration("TEXT")
pcell_decl || raise("Unknown PCell 'TEXT'")
if $mirror.to_s == "TRUE"
mirror = TRUE
else
mirror = FALSE
if $inverseText.to_s == "TRUE"
invertedBool = TRUE
else
invertedBool = FALSE
# assume the coordinates are micron units
x = ($X.to_f / ly.dbu + 0.5).floor
y = ($Y.to_f / ly.dbu + 0.5).floor
# Set the parameters (text string, layer to 10/0, magnification to 2.5)
# Build a param array using the param hash as a source.
# Fill all remaining parameter with default values.
pv = pcell_decl.get_parameters.collect do |p|
param[p.name] || p.default
# Create a PCell variant cell
pcell_var = ly.add_pcell_variant(lib, pcell_decl.id, pv)
t = RBA::CplxTrans::new(1, $rotation.to_i, mirror, x, y)
#Get top cell of file
ly.top_cells.each { |curCell|
pcell_inst = ly.cell(curCell.name).insert(RBA::CellInstArray::new(pcell_var, t))
ly.rename_cell(curCell.cell_index, curCell.name + ":" + $SN.to_s)
break
#Rename the TEXT we just inserted else later when we merge this will cause data to be loss
ly.each_cell_top_down { |curCell|
if ly.cell(curCell).name == "TEXT"
ly.rename_cell(curCell,"TEXT:" + $SN.to_s )
#ly.rename_cell(ly.top_cell.cell_index, $SN)
ly.write($outputFile)
Any help would be great.
Keil
Hi Keil,
thanks for this well-prepared test case!
However I'm afraid I can't reproduce that immediately. I tried with version 0.24.4. Lacking your input file I tried with an empty file (no layers, just a single top cell) and the command line you give in the script. The result is a rotated and mirrored text on layer 9/210 as expected.
Ok thanks for trying. I will play around with it more and see if i can figure it out.
Nevermind my fault the code works fine. I was not calling the script from the command line correctly in my program. So when the script didn't have dataType as a command line argument it just assigned it a zero.
Sorry about creating this discussion it can be deleted.
Thanks for your help Matthias.
Hi Keil,
never mind. Thanks for giving feedback.
