For example to put it at the end of the tools menu, in Macro IDE, click orange "Properties" button (you have to hover over it to see what it's called), then check "Show in menu" and type:
tools_menu.end
While you are in this dialog box, click "Read more about menu paths" just under the thing you just typed.
To show it after the existing "Diff tool" in tools menu, type
tools_menu.diff_tool
To show it in the toolbar, type
@toolbar.end
If you want to know what to type, you can find these in File > Setup > Key bindings. For example that is where I found that the diff tool's path is "tools_menu.diff_tool"
http://www.klayout.de/doc/about/macro_editor.html, scroll down to where it talks about "Show in menu"
David
It's great. Thank you David.
