Thank you for the great tool.
I have a question during the use of this helpful tool.
Is there any way to convert "klayout drc report format" to "rve db format"?
I would like to run DRC by klayout and explore markers on the source OA data. So I need to use rve.
elgoog
Hi elgoog,
welcome to the forum :-)
Right now there is no way to save RVE data from the DRC function, except if you code that export yourself.
But there is a workaround that may be helpful: instead of writing RVE you could write an OASIS or GDS file. RVE supports overlaying of layouts, so I think you can overlay this layout with the OA data.
BTW: There is no OA support in KLayout, because their license model is incompatible with GPL. Sorry.
Thank you for your advice.
It is very helpful and I will try it.
I could also understand the license situation of OA.
elgoog
