Hi there,
First of all, thanks a lot for the great job on KLayout (and the XSection too)! I'm using it for a few years now, it's just perfect :o)
I've decided to experiment some ruby scripting now...
So, I'm using a KLayout command line to do some check on a GDS (size, boundary layer...), and I was wondering how to pass some arguments to my Ruby script (some checks are technology dependant, I need to tell the script which one to use).
Can't find in the documentation, can someone help me?
Seb
-rd <name>=<value> Specify ruby variable
:oP
I had the same problem. It's documented though:
http://www.klayout.de/command_args.html
But please tell me how you can find this link from the menu? I can't find any menu item. I would expect this to be present somewhere under Documentation.
But Google is your friend.
Theo
klayout -h
I don't know from the GUI, but I suppose that if you need a command line option, you should have access to the commande line help :o)
Yes I know. But if an argument is not working as the short -h tells you, you want to read the manual. That was what I experienced.
I think it's just a matter of updating the website by adding a link somewhere in the menu.
Hi all,
the link is available in "Documentation/General - Resources/Command line options". Not missing, just hidden :-)
There is a little more there - just be curious.
