first of all, thank you very much for that nice software and implementing the python scripting engine. It is really fun working with klayout.
As said in the title I would like to know how to convert a Basic.TEXT PCell to a polygon so that I can use it in a boolean operation. I the end I want to get an inverted text in the layout. The easiest way to do that using the GUI is to create a Basic.TEXT instance, flatten the top cell and then draw a box with the difference background-mode around the text object. What would be the equivalent using a script? I got a little further by converting the PCell in a static cell but still I cannot figure out how to do boolean operations between static cells and polygons (regions).
Regards, Christian
I found a way to get what I want but it seems a bit cumbersome. I write the text to a new layer and use cell.top.begin_shapes_rec(layer) to convert all objects from that layer into a region. Then I can use the boolean operations on the regions and write the result back to the layer where I want the inverted text to appear.
Hi Christian,
thanks for this nice feedback :-)
The Basic.TEXT PCell already has a "inverse" option. With this option, the text will be "holes". Did you try this option? It's available below the "magnification".
