Hi, Matthias,
When I read Calibre rdb file with tagged values which value name with empty space, the tagged value wouldn't show in the marker list.
If it is possible to modify it ?
For example
p 1 4
DA X 0.66064
DA density_exclude 0
DA CHIP_NOT_exclude 25
28125000 6125000
28175000 6125000
28175000 6175000
28125000 6175000
Canny
Hi Canny,
sorry, I don't understand the question. Maybe 'which' is supposed to be 'with'? What exactly is the question?
Hi, Matthias,
I modify my example,
It's the output format of Calibre rdb file .
It contants 2 properties ("normal_value" & "abnormal value").
Klayout marker brower could read it and list the property "normal_value", but it wouldn't list property "abnormal value" because it is with space of the property name.
Canny
Hi Canny,
I did not know property names with blanks are valid.
That means, the last blank will separate the value from the property name, right?
Hi, Matthias,
Thank you and yes, the blanks are not allowed of general property name.
But when we use the density function of Calibre, it would be possible to recored the result with the blank
Ex, I use the following key word of my calibre drc deck
The result.rdb would show as
This kind of property name with blank only shows in the rdb file written with the Calibre density function.
And, Yes, the last blank will seperate the value from the property name.
Canny
