I wonder if it is possible to script a DRC, which checks a layout for a maximum number of polygons/path vertices. In version 3 of the GDS II file format, these are limited to 200.
I need this DRC for an older software tool, which uses this file format.
I could manage to check by Ruby, but got stuck at the output to the DRC report database.
Oliver
Hi Oliver
there is no such DRC rule yet, but you can add one:
But beware: this check is slow since it is implemented in Ruby and it iterates over the flat data.
