Hello Matthias, all
when using library names in the gds save option there is a "small issue" when loading then saving.
For exemple let say that i am working on a given gds library. then i load another gds, which is a library (which was affected a library name previously) do some mods and save it
When doing a simple save of the first library, the libray name used, is the library name of the second (latest) loaded/saved gds.
The only way to keep the library name is to use the save as menu.
Using writer options is also taking the library name of the latest loaded/saved file
Not a major issue when knowing the problem. But some time annoying since the normal/usual action will be to use save.
Regards
JoËl
Hi Joel,
I understand your point. I'll see what I can do. The library name is currently not a property of the layout but of the writer settings. In your application it's better to regard it an attribute of the layout and write it.
