Trace net - Kalyout
edited November 2010 in KLayout Support
I'm working on a GDS2 file and using the tracenet tool.
I would like to know if it could be possible to get all the instances connected to a selected net. TraceNet returns a cell type list.
Jean-Yves
  • edited 3:14PM
    Hi Jean-Yves,
    by "instances" I assume you mean the placement and orientation of the specific cell, right?
    Internally, the transformation of the cell in the top cell is known. I can extend the display so it not only shows the cells but the placement and orientation as well. Is that what you are looking for?
  • edited 3:14PM
    Yes, you're right. I'm looking for the locations and the orientations of all the cells connected to the net. Your display extension suits me.
    Thank you for your work and your time
    Jean-Yves
  • edited December 2010
    Hi Jean-Yves,
    The current version 0.21 already has a "detailed" check box in the net tracer dialog to show the cell instance details.
    It's also worth mentioning the text export which allows to produce a text file containing the net items. The text file is actually XML and has a structure like that:
    <?xml version="1.0"?>
    <nets>
     <net>
      <name>Net1</name>
      <top_cell>chip</top_cell>
      <layout>/home/matthias/designs/chip.gds.gz</layout>
      <dbu>0.001</dbu>
      <complete>true</complete>
      <shapes>
       <element>
        <layer>1/0</layer>
        <cell>macro_block</cell>
        <trans>r0 *1 2572000,3640000</trans>
        <shape>box (129700,931500;129900,933700)</shape>
       </element>
      </shapes>
     </net>
    </nets>
    This file may be useful for other applications as well.
