I am trying to design gaurd rings for a silicon strip detector using python. I used the following ways but it doesn't seem to work.
hull = [pya.Point(0/0.001,0/0.001), pya.Point(6000/0.001,0/0.001), pya.Point(6000/0.001,3000/0.001), pya.Point(0/0.001, 3000/0.001)]
hole1 = [pya.Point(1000/0.001,1000/0.001), pya.Point(2000/0.001,1000/0.001), pya.Point(2000/0.001,2000/0.001), pya.Point(1000/0.001,2000/0.001)]
1---->poly = pya.Polygon(hull).insert_hole(hole1)
2----->top.region(l1).insert(pya.Polygon(hull).insert_hole(hole1))
3------>l1.insert(pya.Polygon(hull).insert_hole(hole1))
4------>poly = pya.Region(pya.Polygon(hull).insert_hole(hole1))
Hi
the right way is
