Unable to make klayout v0.21
edited December 2010 in KLayout Support
I download the klayout v0.21(11/29) then tried to make it, however the following error is encountered, the compiler/library environment is good to make klayout v0.20, could you please kindly help to solve our issue? thank you so much.
gcc version: 3.4.3
qt4 version: 4.4.3
/source/klayout-0.21/src/layMainWindow.cc: In constructor `lay::MainWindow::MainWindow(QApplication*, const char*)':
/source/klayout-0.21/src/layMainWindow.cc:381: error: `setTabPosition' undeclared (first use this function)
/source/klayout-0.21/src/layMainWindow.cc:381: error: (Each undeclared identifier is reported only once for each function it appears in.)
Best Regards,
chhung
  • edited December 2010
    Finally I marked this line(setTabPosition) in layMainWindow.cc and compiled it ok without errors,
    the program seems work fine too.
    Best Regards,
    chhung
  • edited November -1
    Hi chhung,
    Even though Nokia does not state that explicitly, the setTabPosition method seems to require Qt 4.5 at least. For 4.4 it is sufficient to comment out that line.
    I'll add a #if to allow building with earlier versions of Qt in the next release.
