Cell Copy Scaling Issue
edited March 2017 in General
I've copied a cell from a different panel to another, but have noticed that the dimension of the sketches are increasing 10 times on the new panel. However, it remains the same on the old one. Could someone help?
Vivek
  • edited March 2017
    Hi Vivek,
    that will happen if the database units of the layouts are different. In general you should make sure you're working with a common database unit.
    Please check whether this is the case and correct that by saving the layout with a different database unit. It's safer to chose a smaller one, so you should correct the one with the bigger DBU to the smaller DBU.
    To avoid rounding issues, you should save to a database unit that is an integer fraction of the current one (for example 0.01 -> 0.001).
