Hi Rambir,
The function you refer to is transforming the layout. It does not leave a value somewhere. So you can't extract that value later.
What exactly is your application?
Hi Rambir,
Sorry for sleeping on this. Well it was the issue with the usage of the Layout transform, the user needed to use instance transform using selection->rotate instead of global transformation.
I could survive by educating him on this.
Thanks & Regards
Rambir
