I need to draw some discontinuous lines onto a circle (360°) from center of circle to diameter ( a little as sun )
lines have a thickness = l and lenght = L
theta is an input , and determines number of lines on 360°
discontinuous lines (= lines with space ) are an random function , not space at same place
may be space would be an % of lenght of line
do you have an idea to do this in ruby ?
or just for beginning , to create some random lines with space
thanks
try this:
thanks , but the real pb for me is to do same thing with discontinuous lines in place of radius lines.
or to had , in a second layer some random space ( or blank ) on previous lines to do discontinuous lines after boolean operation.
and very important , blank ( or space ) on lines will be random from radius line.
after , in my mind ; i will have choice to select number of blank ( or space or discontinuous area), for example 1 to 5 blank by radius line , and so , a % of lenght of radius line.
Hi Phil,
this is just a sample. Please adjust it to fit your requirements.
