Feasibility and Approach for Opening GDSII Files in KLayout via Plugin
Hi Team,
We have a requirement where a GDSII file is stored in our application, and the file needs to be opened in KLayout directly.
Our approach is to develop a KLayout plugin that will:
  1. Authenticate and create a session with the application via REST APIs.
  2. Download the GDSII file locally.
  3. Programmatically load the file into KLayout.
Please let us know:
  1. If this use case is supported via KLayout plugins.
  2. Any recommended guidelines or steps for implementing this integration.
Simran
  • edited December 20
    Hi Simran,
    I think you need to be more specific. What is the requirement UI-wise and what are the details?
    Basically, KLayout can download from HTTP(S), but authentication supports Basic only, is per-session and requires the user to enter a password into a form.
    You can do the download approach you mentioned by using third-party clients such as curl. You do not necessarily need to download as KLayout supports pseudo-paths with the "pipe" scheme:
    pipe: curl https://www.klayout.org/klayout-pypi/samples/basic.gds
    With curl, you can many more authentication options. If you REST API supports token-based authentication, you can include the token in the curl call using additional header fields for example.
    Also, KLayout includes a binding to Qt's QNetwork module. This gives you a lot of flexibility, but it's kind of low-level and implementation of the authentication process may be tedious.
