Hi Team,
We have a requirement where a GDSII file is stored in our application, and the file needs to be opened in KLayout directly.
Our approach is to develop a KLayout plugin that will:
Authenticate and create a session with the application via REST APIs.
Download the GDSII file locally.
Programmatically load the file into KLayout.
Please let us know:
If this use case is supported via KLayout plugins.
Any recommended guidelines or steps for implementing this integration.
Simran
Hi Simran,
I think you need to be more specific. What is the requirement UI-wise and what are the details?
Basically, KLayout can download from HTTP(S), but authentication supports Basic only, is per-session and requires the user to enter a password into a form.
You can do the download approach you mentioned by using third-party clients such as curl. You do not necessarily need to download as KLayout supports pseudo-paths with the "pipe" scheme:
With curl, you can many more authentication options. If you REST API supports token-based authentication, you can include the token in the curl call using additional header fields for example.
Also, KLayout includes a binding to Qt's
QNetworkmodule. This gives you a lot of flexibility, but it's kind of low-level and implementation of the authentication process may be tedious.Matthias
Hi @Matthias ,
Thanks for your response. Let me clarify the use case in more detail, especially from a UI and workflow perspective.
The starting point is an XML file available on the local system. This XML file contains an identifier (or metadata) that references a GDSII file stored in our application backend.
What we would like to achieve using KLayout is the following flow:
The user opens the XML file using “Open with KLayout” from the local system.
When KLayout starts, a custom UI (dialog) is shown that asks for:
along with a Login button.
On clicking the Login button, KLayout establishes a session with our application via REST APIs.
After successful authentication, the plugin parses the opened XML file, extracts the GDS reference ID, and searches for it in the application.
The corresponding GDSII file is then retrieved and opened in KLayout (via a local temporary file download).
Could you please confirm if this overall approach aligns well with KLayout’s plugin capabilities, and if there are any recommended steps or best practices we should follow for implementing this workflow?
Simran
Hi Simran,
Thank you for raising this interesting topic. It prompted me to experiment with an alternative approach outside of a KLayout plugin.
Rather than embedding authentication and REST handling inside KLayout, I tried a small external launcher (built with PySide6) that reads an XML file containing a GDS reference ID, communicates with a REST backend, downloads the corresponding GDSII (and LYP) files, and then launches KLayout explicitly from the command line.
In this setup, KLayout is kept as a pure viewer/editor without plugins or internal API dependencies, which can simplify testing and reduce long-term maintenance concerns.
I have attached the full prototype code along with a detailed ReadMe.md describing the architecture, design rationale, and test environment.
Please refer to that document for the complete context before diving into the code itself.
For reference, this experiment was carried out on an M4 Mac mini running macOS Tahoe 26.2, using Python 3.13 from MacPorts.
Personally, this was also a nice opportunity for me to deepen my understanding of REST-based workflows, so thank you for initiating the discussion. It may be useful to consider this kind of separation-of-responsibilities approach alongside a plugin-based solution, depending on project constraints.
Kazzz-S
In the local server & client environment...
Hi @sekigawa
Thank you for sharing the external launcher prototype and the detailed explanation. I appreciate the time and effort you put into exploring this alternative and documenting the design choices.
While the separation-of-responsibilities approach is interesting, for our project we are more inclined towards a plugin-based solution within KLayout, mainly to keep the entire workflow (authentication, lookup, and GDS loading) seamless inside KLayout and avoid an additional external tool.
With that in mind, I wanted to specifically ask for guidance on initiating this use case using KLayout plugins:
Any high-level guidance on how you would structure such a plugin would be very helpful for us to move forward.
Thanks again for the insightful discussion.
Simran
Hi @sekigawa,
thanks for this impressive survey
@simransingh14: regarding the plugin-based approach: it is not possible to explicitly capture the "File/Open" event. "Plugins" are scripts that make use of a special API to hook into KLayout's layout view API and allow creating new layout editing or measurement tools.
It may be possible to modify the behavior of the "File/Open" menu button using the Qt objects involved, but I'd not recommend that as the details may depend on Qt versions and may be subject to change without notice.
But you can:
klayout -rm yourscript.py.c:\users\youraccount\KLayouton Windows or~/.klayouton Linux).To configure a macro for autorun or menu binding, use these options:
There are some concerns however:
There are no known limitations regarding temporary files. You can use Python's "tempfile" for example to create a temporary file. If your files are not too big and fit into memory, you can even use
Layout#read_bytesto read directly from a binary string orQByteArrayobject and avoid the temporary file.Kind regards,
Hi @simransingh14,
I have completed a second research prototype based on this discussion.
In the first prototype, I explored an external PySide6 launcher that authenticates via REST,
downloads GDS/LYP files, and launches KLayout explicitly from the command line.
In this second prototype, I interpreted the term “plugin” (as discussed by Matthias)
as a menu-registered GUI implemented in Python (PYA) inside KLayout:
The mock backend server and test data are reused unchanged from the PySide prototype.
The UI is intentionally read-only, with the XML file acting as the single source of truth.
From an implementation standpoint:
Platform observations:
Python module and packaging limitations previously mentioned by Matthias
This reinforces the earlier architectural conclusion:
for strict cross-platform robustness (especially Windows),
an external launcher approach may still be preferable.
The full README, including design rationale and comparison with the PySide prototype,
is attached for reference.
Thanks again for the insightful discussion — this was a very useful exercise
to explore both architectural directions.
General Usage
$HOME/.klayout/pythondirectory. Symbolic links also work.mock_backend.pyin a terminal.Sample Run
mock_backend.py: running onLinux Mint 21.3.Forum2834.pyin KLayout: running onmacOS Tahoe(Apple Silicon).Best regards,
Kazzz-S
