Using klayout to mess with some old survey DXFs,
the ruler label text is set up sensibly but hard copy
magnifies the ruler text by about 10X and looks a
bit kooky.
What controls that scaling, for the print process?
Other features look same-same vs display.
Hmm ... I have a few samples with rulers and they look good to me.
Do you have a sample file that shows this effect?
Couldn't figure out how to show the printed
output, other than this:
I see
Initially I understood you mean the dimension objects in DXF.
It does not look bad in my case ... but maybe that is only my hardware combination. I will try on other screens and printers.
Does the problem also occur if you print to PDF?
