Ruler labels print far larger than they display
Using klayout to mess with some old survey DXFs,
the ruler label text is set up sensibly but hard copy
magnifies the ruler text by about 10X and looks a
bit kooky.
What controls that scaling, for the print process?
Other features look same-same vs display.
  • Hmm ... I have a few samples with rulers and they look good to me.
    Do you have a sample file that shows this effect?
  • Couldn't figure out how to show the printed
    output, other than this:
  • I see :)
    Initially I understood you mean the dimension objects in DXF.
    It does not look bad in my case ... but maybe that is only my hardware combination. I will try on other screens and printers.
    Does the problem also occur if you print to PDF?
