Returning value of : cell_name vs filename
Based on the documentation
https://www.klayout.de/doc-qt5/code/class_CellView.html#h2-138
 [const]    string  cell_name       Gets the name of the target cell currently addressed
 [const]    string  filename        Gets filename associated with the layout behind the cellview
pya.LayoutView().current().active_cellview().cell_name -> "test"
expected
pya.LayoutView().current().active_cellview().filename -> <built-in method filename of CellView object at 0x7f2ff9f280d0>
not what I expected !
both are '[const] string' should both return a string ?
However
pya.CellView().active().filename() -> test.GDS
does what I was expecting from
feature, bugs or missing something ?
  • Documentation problem, filename is not a string anymore
    Originally I did not tried this
    pya.LayoutView().current().active_cellview().filename()
    it works.
