Returning value of : cell_name vs filename
Based on the documentation
https://www.klayout.de/doc-qt5/code/class_CellView.html#h2-138
 [const]    string  cell_name       Gets the name of the target cell currently addressed
 [const]    string  filename        Gets filename associated with the layout behind the cellview
pya.LayoutView().current().active_cellview().cell_name -> "test"
expected
pya.LayoutView().current().active_cellview().filename -> <built-in method filename of CellView object at 0x7f2ff9f280d0>
not what I expected !
both are '[const] string' should both return a string ?
However
pya.CellView().active().filename() -> test.GDS
does what I was expecting from
feature, bugs or missing something ?
  • Documentation problem, filename is not a string anymore
    Originally I did not tried this
    pya.LayoutView().current().active_cellview().filename()
    it works.
  • Not a documentation problem:
    cell_name: doc says
    Python specific notes:
    The object exposes a readable attribute 'cell_name'. This is the getter.
    So it's an attribute. Use object.cell_name.
    filename: no such comment. So it's a method. Use object.filename().
    Or use Ruby. There is no such differentiation needed.
