I have tried to transfer a SKY130 magic file .mag to KLayout. It can be read, but the GDS numbers are not OK, only the layer names even if I use the layer mapping such as (also attached) :
NWELL:64/20
DIFF:65/20
TAP:65/44
DNWELL:64/18
What is the proper method to read a SKY130 mag file with KLayout ? Maybe the mapping is sensitive to layer name case ?
Thank you, BRgds,
Hi Laurent,
I just tried to reproduce the issue, but it seems to work for me:
with "map.txt":
gives me a GDS file with the layers mapped.
However, I found a problem when the map is not fully specified - i.e. some layers are in the Magic file that are not mapped - in that case, KLayout stalls (https://github.com/KLayout/klayout/issues/2438).
In general, Tim advises against KLayout, since Magic does some magic translating vias and for other reasons. So the recommended method is to use Magic to convert to GDS.
Indeed, I have installed and used magic command : gds write output.gds
And my goal was to check if I can get the same result from a KLayout import mag file, because magic is only on linux, not on windows.
BRgds,
