Red Hat Enterprise Linux Version 5.3 for 32 bit x86 System Qt Query
edited February 2010 in KLayout Support
The folks at RH tell me Qt version 3.3 is the supported version RHEL 5.3 on 32bit x86 systems. Will Klayout work if built with it, or must I update Qt?
    Hi Rosario,
    KLayout requires at least Qt 4. Usually there is a Qt 4 package you can install in parallel to Qt 3.
    I would recommend 4.5.x, but any Version >=4.1.x should do. You can also try 4.6.x. It should work, but I don't have much personal experience with that one.
    I found the updates:
    Application>add/remove software> goes into package manager, check the following boxes and apply:
    qt4-4.2.1-1.i386
    qt4-devel-4.2.1.1.i386
    qt4-doc-4.2.1.1.i386
    thank you
