Hi All,
Once again, I need your help.
How to make the visibility of the
layer "METAL1.drawing - 16/0" and "METAL2.drawing - 18/0" to become invisible
in the active cellview by using Ruby ?
I'm using kLayout 0.23.2 .
that is a little bit more tricky since layers are not addressed directly. Instead the layer list is an object by its own and the concept is that you traverse the layer list tree with a LayerPropertiesIterator in a read-only fashion. Once you have identified that layer you want to change, you can modify it by assigning new layer properties to the current node, i.e.
view = RBA::LayoutView::current
# The following loop traverses the tree/list
li = view.begin_layers
while !li.at_end?
# Identify the current properties and they match with the ones we look for
# change them
lp = li.current
if lp.source_layer == 16 && lp.source_datatype == 0
# To change the properties, create a copy, modify the attributes
# and replace the current properties
new_lp = lp.dup
new_lp.visible = false
view.set_layer_properties(li, new_lp)
li.next
It works .
How about if I want to make all layers to be invisible,
and make the layer "METAL1.drawing - 16/0" to be the layer
that is visible.
Hi Mathias,
I think I have solve my problem.
First I make the all layers invisible.
Then I make "METAL1.drawing - 16/0" or any other layers that I want to be visible.
My code is like these :
# Enter your Ruby code here
# Make all layers invisible .
while !li.at_end?
# change them
lp = li.current
new_lp = lp.dup
li.next
end # while
# Begin the display of layer 16 and layer 17 .
while !li.at_end?
# change them
lp = li.current
# commented
if lp.source_layer == 16 && lp.source_datatype == 0 || lp.source_layer == 17 && lp.source_datatype == 0
new_lp = lp.dup
new_lp.visible = true
Thank you very much for your reply.
But there is an error .
"lp = li.current" is missing.
I add it in your code, it is now working like a charm.
Modified code is below.
while !li.at_end?
# change them
lp = li.current
new_lp = li.current.dup
new_lp.visible = (lp.source_layer == 16 && lp.source_datatype == 0)
if layer_node.source_datatype == 0 && layer_node.source_layer == 1
dup = layer_node.dup
dup.visible = false
cell_view.set_layer_properties(layer_prop, dup)
break
layer_prop = layer_prop.next
cell_view.save_image($output, 1153, 618)
Here is the command line used:
But the output image has all the layers shown. I am very new to both Ruby and KLayout so there can be a lot of coding errors. I'd appreciate it if you can help me on this.
I noticed that you might need "cell_view.update_content" before "save_image". That is not quite obvious and it should not be necessary, but "update_content" (among other things) basically synchronizes changes in the layer properties with the renderer and that may help here.
Hi Marben,
It works .
that is visible.
Best Regards,
Marben
while !li.at_end?
# change them
lp = li.current
new_lp = lp.dup
li.next
end # while
while !li.at_end?
# change them
lp = li.current
# commented
new_lp = lp.dup
end #If
li.next
end #while
Best Regards,
Marben
Hi Marben
bascially you could have it as simple as that:
while !li.at_end?
# change them
lp = li.current
li.next
Best Regards,
Marben
You're right. I edited the code above.
Thanks, Matthias
I have a question related with this. I have tried to selectively hide some layers and save the image of the layout with the following code:
main_window = RBA::Application::instance.main_window
main_window.load_layout($input, 0)
layer_view = main_window.current_view
layer_view.max_hier
cell_view = RBA::LayoutView::current
layer_prop = cell_view.begin_layers
while layer_prop != layer_view.end_layers
layer_node = layer_prop.current
dup.visible = false
break
Hallo,
Thanks you so much!
