Changing The Layer Visibility by using Ruby .
edited February 2014 in Ruby Scripting
Hi All,
Once again, I need your help.
How to make the visibility of the
layer "METAL1.drawing - 16/0" and "METAL2.drawing - 18/0" to become invisible
in the active cellview by using Ruby ?
I'm using kLayout 0.23.2 .
Best Regards,
Marben
    Hi Marben,
    that is a little bit more tricky since layers are not addressed directly. Instead the layer list is an object by its own and the concept is that you traverse the layer list tree with a LayerPropertiesIterator in a read-only fashion. Once you have identified that layer you want to change, you can modify it by assigning new layer properties to the current node, i.e.
    view = RBA::LayoutView::current
    # The following loop traverses the tree/list
    li = view.begin_layers
    while !li.at_end?
      # Identify the current properties and they match with the ones we look for
      # change them
      lp = li.current
      if lp.source_layer == 16 && lp.source_datatype == 0
        # To change the properties, create a copy, modify the attributes
        # and replace the current properties
        new_lp = lp.dup
        new_lp.visible = false
        view.set_layer_properties(li, new_lp)
      li.next
    It works .
    How about if I want to make all layers to be invisible,
    and make the layer "METAL1.drawing - 16/0" to be the layer
    that is visible.
    Best Regards,
    Marben
    Hi Mathias,
    I think I have solve my problem.
    First I make the all layers invisible.
    Then I make "METAL1.drawing - 16/0" or any other layers that I want to be visible.
    My code is like these :
    # Enter your Ruby code here
    # Make all layers invisible .
    while !li.at_end?
    # change them
    lp = li.current
    new_lp = lp.dup
    li.next
    end # while
    # Begin the display of layer 16 and layer 17 .
    while !li.at_end?
    # change them
    lp = li.current
    # commented
    if lp.source_layer == 16 && lp.source_datatype == 0 || lp.source_layer == 17 && lp.source_datatype == 0
    new_lp = lp.dup
    new_lp.visible = true
    end #If
    li.next
    end #while
    Best Regards,
    Marben
  • edited February 2014
    Hi Marben
    bascially you could have it as simple as that:
    while !li.at_end?
      lp = li.current
      new_lp = lp.dup
      new_lp.visible = (lp.source_layer == 16 && lp.source_datatype == 0)
      li.next
    Thank you very much for your reply.
    But there is an error .
    "lp = li.current" is missing.
    I add it in your code, it is now working like a charm.
    Modified code is below.
    while !li.at_end?
    # change them
    lp = li.current
    new_lp = li.current.dup
    li.next
    Best Regards,
    Marben
    You're right. I edited the code above.
    Thanks, Matthias
    I have a question related with this. I have tried to selectively hide some layers and save the image of the layout with the following code:
    main_window = RBA::Application::instance.main_window
    main_window.load_layout($input, 0)
    layer_view = main_window.current_view
    layer_view.max_hier
    cell_view = RBA::LayoutView::current
    layer_prop = cell_view.begin_layers
    while layer_prop != layer_view.end_layers
    layer_node = layer_prop.current
    if layer_node.source_datatype == 0 && layer_node.source_layer == 1
    dup = layer_node.dup
    dup.visible = false
    cell_view.set_layer_properties(layer_prop, dup)
    break
    layer_prop = layer_prop.next
    cell_view.save_image($output, 1153, 618)
    Here is the command line used:
    But the output image has all the layers shown. I am very new to both Ruby and KLayout so there can be a lot of coding errors. I'd appreciate it if you can help me on this.
  • edited April 2014
    Hallo,
    I noticed that you might need "cell_view.update_content" before "save_image". That is not quite obvious and it should not be necessary, but "update_content" (among other things) basically synchronizes changes in the layer properties with the renderer and that may help here.
    It is working after inserting "cell_view.update_content" before "save_image".
    Thanks you so much!
