Sorry to bother you again~
I tried to open a gds file then hide all layers besides one layer we need, and the main window only show five objects.
When I select an area include these five objects, a running scroll at the right bottom of main window appeared and shows "selecting", even only five objects it spends a long long time.
Finally I found the element would effect the speed is edit=>select=>instances , if the option is checked, the program would check all the objects even these objects should not be visible because the layers are hide.
Is this situation correct or could be improved?
Another problem, is it possible to list the absolute coordinates/positions of selected text objects?
like this:
text1(11.00000,22.00000)
text2(89.01000,55.10000)
Best Regards,
chi-hsiang-hung
thanks for the hint about the speed issue. I'll try to reproduce that and find a solution for it.
Regarding the second request: there is a check box in the property page named "absolute (accumulated) transformations". Thats probably somewhat misleading but checking the box should give the desired results.
The reason why we hope a function to list all the coordinates selected is,
when trying to get coordinates from many text objects, we have to select
all the objects and open the properties window, copy/paste the position,
click the next button and repeat this procedure many times.
Is there another way to do such action faster? Your kindly support
would be highly appreciated.
Best Regards,
chi-hsiang-hung
The following script may be helpful to fulfil your request: It dumps the absolute coordinates of all text objects selected to a file in the format "TEXT(x,y)".
Here is the code:
Very thanks for your code, it fits our requests at all,
your kindly support is really a best Christmas gift. :)
Merry Christmas & Happy New Year!
Best Regards,
chi-hsiang-hung
I have a large file and I'm trying to locate a label saying "sen2" in it.
If I save the GDS file as text I can findthe following-
TEXT
LAYER 30
TEXTTYPE 4
PRESENTATION 6
STRANS 0
MAG 0.5
XY 16000: 137000
STRING sen2
ENDEL
So now I try to lacte this label, but the Y coordinate is out of the die so probably these coordinates need some conversion.
How can I find this label?
Thanks much, Itamar
I was able to find this label in the design but still could not figure how to transform coordinates.
Another q: How can I have this label attached to it's net. When I trace this net, I want this net to show "sen2". I tried to connecet this label layer (30:4) to the top metal layer but this still does not show.
Hi Itamar,
I guess the text object is somewhere in a child cell. In order to get the final location, you'll have to flatten the cell or you apply the transformation of the cell instances to the shape. A handy class is the RecursiveShapeIterator which delivers shapes from all over the hierarchy and also collects the transformations along the instantiation paths.
In order to detect nets, you can declare 30/4 as a metal layer and connect it to a metal layer. For example, if you have metal on 30/0, you can define the following connection in the layer stack:
30/0 - None - 30/4
This will use the texts as net names when they are over metal in 30/0. But beware, if there are multiple texts - the net tracer will just use one.
