I interpret this to mean that you want a dialog box, with two dropdown menus. The first is populated with the layer/datatypes in the current layout, and the second is populated with the list of cells.
If so, download and install TRT, then look at: TRT menu > Cells > Get PCell parameters. That script has a dialog box with two dropdowns. All that remains is to populate those dropdowns differently.
To get a list of the layer/datatypes, use something like
Hi jmhutchi,
To get a list of the cells beneath the current one in the current layout, use something like
Did this answer your question?
David
