I am currently struggling with a problem for library cell replacement in a layout.
Let's me expose the problem so that it is clear enough:
I have a gds library called foo and a 2nd one called foo1
in this library i have cells
bar
bar1
bar2
and in foo1 i have
bar
bar4
Now i use this library in a new layout, my layout is like this:
top cell
child cell
foo.bar
foo.bar1
now i want to replace foo.bar1 by foo.bar2 and foo.bar by foo1.bar
in klayout, two ways are provided to replace cells:
the replace cell command and the replace with other. To use replace cell you have to have in your layout the cell with which you want to do the replacement. For this i create an instance, for example foo.bar2 in the layout. then i use the replace cell command. this is not working, klayout telling me "not a valid cell name" whatever i choose from shallow replace to complete replace.
If i use the replace cell with other (ruby script) (for example foo.bar and foo1.bar) things are working better, since all the cells belonging to the selected library are imported in the layout (and the cell is properly replaced if there is a cell with the smae name in the library)
However the library link is lost during the operation (foo1.bar becomes bar, not anymore linked to the library foo1...)which is not that nice.
I tried to implement a new macro based on this replace cell with other but i am struggling at doing a working code !!!
Any help ?
Regards
Joël
You can close this item, i think i found the solution by myself.
sorry for the disturbance...
Joël
Very good :-)
I usually don't delete discussions. If you like you can state your solution here - this might be useful for other users too.
Joël
I am not aware of the solution either. But I guess the general misconception is to replace "cells". In fact you can only replace "instances".
So the solution is
A general note on library cells: KLayout's concept of libraries is not that of a "link" as the question suggests. Instead, a library cell is a weakly linked copy of the original library cell. The advantage is that the layout can live independently from the library. But once the link is broken it's hard to recover. The names "LIB.NAME" are just visual clues - they don't imply a link to the library.
Again, maybe not very clean coding style...
How to use:
put the cell to be replaced as active (cell name in bold)
then right clock and select Replace Lib and Cell.
use the drop down menu to select the library/cell
should do the trick
# $description: Lib-and-cell-replace
# $version: 1.0
# $autorun
# replace lib & cell script
# define a new Menuaction class
include RBA
self.title = title
self.shortcut = shortcut
@action = action
def triggered
@action.call( self )
private
@action
#define replace function
$replace_lib_cell = MenuAction.new("Replace lib and cell", "") do
# new dialog class for library and cell selection
class ReplaceDialog < QDialog
include RBA
def initialize(parent = nil)
super
setWindowTitle("Lib/Cell Exchange dialog")
winlayout = QGridLayout.new(self)
setLayout(winlayout)
# gds layout/cell view
mw = app.main_window
# work on gds current view
lv = mw.current_view
if lv == nil
raise "Shape Statistics: No view selected"
#cellview is the active one
cv=lv.active_cellview
if !cv.is_valid?
raise "No cell or no layout found" # non: on s'arrête
layout=lv.cellview(0).layout
cell_to_rep = lv.active_cellview.cell.name # cell to be replaced is the active/selected cell (Ctrl S)
cell_to_rep_id = layout.cell_by_name(cell_to_rep) # index value of the cell to be replaced
if lv.active_cellview.cell.is_library_cell?
library_to_rep = lv.active_cellview.cell.library.name # library of the cell to be replaced (if any)
else
library_to_rep ="local"
cellindex = "" #declare variable first , so that they are "global"
libindex = ""
# dialog construction
l = QLabel.new(self)
l.text = "Origin Library"
winlayout.addWidget(l, 0, 0, 1, 1)
lib_edit = QLineEdit.new(self)
lib_edit.text = library_to_rep
winlayout.addWidget(lib_edit, 0, 1, 1, 1)
c = QLabel.new(self)
c.text = "Origin Cell"
winlayout.addWidget(c, 1, 0, 1, 1)
cell_edit = QLineEdit.new(self)
cell_edit.text = cell_to_rep
winlayout.addWidget(cell_edit, 1, 1, 1, 1)
nlibl = QLabel.new(self)
nlibl.text = "New library"
winlayout.addWidget(nlibl, 2, 0, 1, 1)
ncelll = QLabel.new(self)
ncelll.text = "New Cell"
winlayout.addWidget(ncelll, 3, 0, 1, 1)
libnames ={}
libnames = RBA::Library.library_names
nlib = QComboBox.new(self)
nlib.addItems(libnames) #populate menu with lib names
winlayout.addWidget(nlib, 2, 1, 1, 1)
nlib.activated do
begin
libindex = nlib.currentText # replacement library selected
librar=RBA::Library.library_by_name(libindex)
libcell = librar.layout
libcellname = []
i=1
libcell.each_top_cell do |t|
libcellname[i] = libcell.cell_name(t).to_s # extract lib cell names
i=i+1
libcellname[0]=""
ncell = QComboBox.new(self)
ncell.addItems(libcellname)#populate menu with cell lib names
winlayout.addWidget(ncell, 3, 1, 1, 1)
ncell.activated do
begin
cellindex = ncell.currentText # replacement cell
end #of the library/cell selection
do_ok = QPushButton.new(self) # do button
do_ok.text = "OK"
winlayout.addWidget(do_ok, 4, 4, 1, 1)
do_ok.clicked do # we do the replacement
begin
lib=RBA::Library.library_by_name(libindex)
new_cell_id = layout.add_lib_cell(lib,lib.layout.cell_by_name(cellindex)) # create a new cell id with the replacement cell
cv.layout.each_cell do |ctr| # scan eall the cell in the layout
ctr.each_inst do |inst| # scan each instance of theses cells
if (inst.cell_index == cell_to_rep_id) # scanned cell match the cell to be replaced??
i = inst.cell_inst # yes
trans = i.is_complex? ? i.cplx_trans : i.trans # find & copy which type of geometrical transformation is done on this cell
if i.is_complex?
instancebis=RBA::CellInstArray::new_inst_cplx(new_cell_id,trans) # create an instance of the repalcement cell with the correct geometrical trans
else
instancebis=RBA::CellInstArray::new_inst(new_cell_id,trans)
ctr.replace(inst,instancebis) # replace the "old" cell instance with the replacement cell instance
rescue
$dialog13 = ReplaceDialog.new(Application::instance.main_window)
$dialog13.exec
# implementation of contextual menu
menu = mw.menu
menu.insert_separator("@hcp_context_menu.end", "replace_lib_and_cell")
menu.insert_item("@hcp_context_menu.end", "replace_lib_and_cell", $replace_lib_cell)
Regards
Joël
