Goto position and Snapshot
edited July 2013 in Ruby Scripting
Is there a sample ruby code that describe how to do the action "Goto Position" and then "Snapshot / Screenshot to a PNG file" just like in window mode ?
We hope to get the layout screen with multiple coordinates in batch mode however have no idea how to do that, could you please give us a hint ? thank you so much~
Best Regards,
chhung
  • edited July 2013
    Hi chhung,
    this is code which does that:
    # input file
    input_file = "t10.gds"
    # width, height of image
    width = 500
    height = 500
    # rectangle to draw (left, bottom, right, top in micron coordinates)
    rect_drawn = RBA::DBox::new(-100.0, -200.0, 100.0, 200.0)
    # output file
    output_file = "t10.png"
    # load the layout
    mw.load_layout(input_file, 0)
    view = mw.current_view
    # select full hierarchy and the rectangle to draw
    view.max_hier
    view.zoom_box(rect_drawn)
    # save image
    view.save_image("#{output_file}", width, height)
    Please replace the values by yours. I hope the code is documented well enough, so you're able to adapt it to your needs.
  • edited July 2013
    I tried to run the RBA code and it responsed the error:
    *** ERROR: ./test.rba:9: Ruby error: 'uninitialized constant RBA::DRect' (NameError)
      ./test.rba:9 (class NameError)
    And is it possible to run the code in non-GUI mode ?
    Best Regards,
    chhung
    Sorry, it should say "DBox". I edited the code.
    You can run "klayout -z ..." with the script, but not with -zz. In the latter mode there is no view object and KLayout is a pure layout processor without any graphics.
    I tried the new code and it works fine~ :)
    Thank you so much~
    Best Regards,
    chhung
    Hi, Matthias,
    I have a question about the batch sanpshot.
    Ex, there are total 10 layers of the gds (1/0,2/0,3/0,4/0, ....,10/0),
    I only want to show 1/0, 3/0 and 10/0 layers of the images.
    How could I do that with this batch code?
    Thank you.
    Canny
    Hi Canny,
    the easiest solution is to prepare a .lyp file with the layer properties (colors, stipples, styles and
    the layers you want to show) and load the layer properties:
    # load the layout
    # load the layer properties
    view.load_layer_props(the_path_to_your_lyp_file, false)
    Hi, Matthias,
    Thanks a lot, it does save lot of time of mine.
    Canny
    Hi, Matthias,
    I have another question, when I use the above script
    # script start
    #--script end
    It always shows the top cell of the input file.
    If I want to assign coordinates are according to the other cell of the input file.
    How could I modify the script?
    Thank you.
    Canny
    Hi Canny,
    you mean "how to show another cell"? You can do that this way (in this example the name of the cell to show is "MY_CELL":
    cell = view.active_cellview.layout.cell_by_name("MY_CELL")
    view.select_cell(cell, view.active_cellview_index)
    Hi, Matthias,
    Yes, it is what I need.
    Thank you.
    Canny
    I want to add a function that goes to a specific location within the gdsii/oasis and create a view with a specific magnification. Then I want to take a snapshot such that the pixel width/height is identical if I then perform another goto position/mag and take another screendump. I want to do that repeatedly throughout the gdsii. I tried to find an analog to the display-goto-position (CTRL-G) but cannot find it yet.
    Chris
  • edited June 2015
    Chris,
    Here is some code that reproduces display-goto-position (Ctrl-G) with minor changes. I wrote it before I knew that display-goto-position existed ;)
    Hopefully you can modify for your purposes, e.g. it sounds like you need to put it in a loop of some kind, and you need to add the screenshot function (there are examples on klayout.de to do that).
    When you have a finished code, please share it here.
    David
    ## Zooms viewing window to a certain x,y location with optional magnification
    zoom_default = 500.0 # um
    include RBA
    app = Application.instance
    mw = app.main_window
    lv = mw.current_view
    raise "No view selected" if lv.nil?
    dbu = ly.dbu
    # Get current "x,y : zoom"
    #p curr_x = ... # There is no way to get this using the API??
    #p curr_y = ... # There is no way to get this using the API??
    #p curr_trans = lv.viewport_trans
    #p curr_zoom = lv.viewport_width
    curr_x,curr_y,curr_zoom = 0,0,100 # Temporary, until the above lines work
    input = InputDialog.ask_string(
      "Zoom",
      "Move to x,y location (with optional horiz extent 'zoom') \n
      x,y : zoom",
      "#{curr_x},#{curr_y} : #{curr_zoom}")
    # Error checking
    input = /(\d+(.)?\d*( )?,( )?\d+(.)?\d*( )?:( )?\d+(.)?\d*|\d+(.)?\d*( )?,( )?\d+(.)?\d*)/.match(input).to_s # This regex is not perfect, but catches most cases
    if input.empty?
      raise "Incorrect format. Use 12.3,45 : 100 or 12.3,45 for example."
    else
      # Remove spaces
      input.gsub!(' ','')
      # Split string
      xy,zoom = input.split(':')
      x,y = xy.split(',')
      # Convert to float
      x = x.to_f
      y = y.to_f
      zoom = zoom.to_f
      if zoom < 1e-4 # If zoom is zero, it's invalid, so use the default zoom
        zoom = zoom_default
      if (x.is_a? Numeric) && (y.is_a? Numeric)
        left  = x - zoom/2.0
        bott  = y - zoom/2.0
        right = x + zoom/2.0
        top   = y + zoom/2.0
        p [left,bott,right,top]
        zoom_box = DBox.new(left,bott,right,top)
        lv.zoom_box(zoom_box)
    Thanks very much again, David!
    Plus here is the line for writing the screenshot:
    # Arguments: file name, image width and height (both in pixels)
    # The format will be PNG.
    lv.save_image("image_file.png", 640, 480)
    Can we do this in pure script mode (-zz) without GUI ?
  • edited January 2017
    Hi klfun,
    no, you can't (currently). The drawing feature is too tighly connected to the Windowing system.
    You can however run any program headless with a dummy display using "Xvfb":
    xvfb-run ./klayout -z -r your_script.rb
  • edited September 2020
    regarding David's script above.
    I think two lines can be changed as below
    #p curr_x = ... # There is no way to get this using the API??** --> curr_x = lv.box.center.x**
    #p curr_y = ... # There is no way to get this using the API??**--> curr_y = lv.box.center.y**
