I think the following functionality is not working as it should. Version 0.24.7.
I also open the text GDS, and find that it doesn't have the User Property I defined. Here is an example GDS:
HEADER 600
BGNLIB 3/18/2017 0:03:27 3/18/2017 0:03:27
LIBNAME SiEPIC-EBeam
UNITS 0.001 1e-09
BGNSTR 3/18/2017 0:03:27 3/18/2017 0:03:27
STRNAME fa
ENDSTR
ENDLIB
You can see the property "lukas" is missing.
I believe GDS spec doesn't allow a string in the Key field.
If you repeat your steps but put
as the Key, and
as the Value, it will work. The hash or pound mark in front of the number 3 means treat it as an integer.
Still, perhaps this could be made more obvious.
OASIS file format preserves any key and value, which I use a lot. Therefore I like OASIS better, but Matthias likes GDS :-)
Hi David,
yes, that's right. And of course that should be more clearly indicated.
Actually the only format supporting user properties in all flavours is OASIS. GDS2 only supports properties with integer keys and string values (while everything will be converted to a string). LEF/DEF generates properties on reading (for example net names), but otherwise, all other formats can't handle user properties.
