Good afternoon,
interesting thing when using Edit->Selection->size shapes to change the size of the shapes. It has no effect if the value is less than 1 in microns. Is it the limitation of the command or has some other way to deal with values less than 1 micron?
Please check whether the database unit is small enough to represent smaller dimensions (typical values are 0.001 µm). The database unit is the basic resolution and every dimension will be confined to multiples of this unit.
its solved everything. My mistake not to look at that.
