I have to perform grow and shrink (size) operations which will take too much memory (>32 GB) when run from a ruby script. To circumvent this I now use a DRC script that supports tiles. This works well.
Is there a ruby equivalent so I can make the changes in place which is more convenient in my case?
Xaveer
Hi Xaveer,
the tiles feature of the DRC is implemented using the TilingProcessor. You can basically use the same for implementing your own tiled size.
