How to save setup on Windows ?
edited May 2011 in General
Hi, I use Klayout on Windows Computer, but more simplicity i want to save diferents setup... But how can i save the setup ?
I have read a topic on a .layviewrc file into the root directory... But i think this file is for Linux and not for Windows use ?
Where is the setup file stored under this "amazing" world of Windows ? :-)
Remi.
    Sorry, my version is : 0.20.1 ;-)
  • edited May 2011
    Hi Remi,
    The .layviewrc file is stored in your home directory (not root). On Windows, that is usually "c:\Users\your_account".
    You can switch setups by providing a path to a specific setup file using the -c option. For example, you can create two shortcuts on your desktop, one using the command line
    "c:\Programm Files\klayout\klayout.exe" -c c:\klayout_setup1 -e "%s"
    and another using the command line
    "c:\Programm Files\klayout\klayout.exe" -c c:\klayout_setup2 -e "%s"
    (Both setup file paths on c: are probably a stupid choice and given as an example only - you should better use "c:\Application Data" or something similar).
    If you select the first shortcut, klayout will use the setup from c:\klayout_setup1, the other shortcut will use the other setup.
    BTW: in the next version, I plan to replace the .layviewrc file and use a folder ($HOME/.klayout) to store more files than just the setup. In that version, the setup file will move to $HOME/.klayout/klayoutrc. The -c option will still be present and behave identical.
    Hi Matthias, Thank you for you support ;-)
    Long life to Klayout ;-)
    Remi
