I would like to create a menu that loads a lef+def file on an existing opened design. Exactlty what I would do by File->import->LEF/DEF and selecting "Import as new layout is the same panel"
The command I use for launching klayout is :
klayout -e -u KLAYOUT/results/gds.lyp -rm ./fastkit_macro.lym
where gds.lyp gives the gds and associated layerProps
the macro I defined for loading the def is as follows but is does not work at all
(stream format is not correct)
module FastkitMacro2
include RBA
$fastkit_action = RBA::Action.new
$fastkit_action.title = "load_DIAG"
$fastkit_action.on_triggered {
RBA::LayoutView::current.load_layout("./DIAG/results/diag.def",2)
RBA::LayoutView::current.load_layer_props("./DIAG/results/diag.lyp")
mw = app.main_window
menu = mw.menu
menu.insert_item("end", "fastkit", $fastkit_action)
Is there a method that can load this format ?
Paul
Hi Paul,
did you try with the latest version (0.25)? For this version, it should be possible to load DEF like any other format.
DEF is richer, so if you want to provide particular configuration options, you'll need a separate configuration object:
For LEF/DEF reader options see http://www.klayout.de/doc-qt4/code/class_LEFDEFReaderConfiguration.html
BTW:
