I need to convert a big set of edges forming polygons into polygons. I need only the resulting polygons without resolving holes (adding connectors). Setting resolve_holes=False in simple_merge_e2p does not help - I still see the connectors in the result. I can of course do this in a loop over edges and creating a polygon every time the edges close. Maybe I am overlooking something and there is a simpler way?
Mikhail
Hi Mikhail,
I can't confirm that simple_merge_e2p doesn't work, but if you're using keyword arguments: that's not supported currently. The arguments are mandatory ones.
