I pulled source code of pymod from github.
Pymod building is passed with HAVE_64BIT_COORD=0.
However, it failed with HAVE_64BIT_COORD=1
Error message is,
In file included from ../../../src/pya/pya/pya.cc:28:0: ../../../src/pya/pya/pyaConvert.h:145:12: error: 'test_type' was not declared in this scope return test_type<int> (rval, loose); ^~~~~~~~~ ../../../src/pya/pya/pyaConvert.h:145:22: error: expected primary-expression before 'int' return test_type<int> (rval, loose); ^~~ ../../../src/pya/pya/pyaConvert.h:145:22: error: expected ';' before 'int' ../../../src/pya/pya/pyaConvert.h:145:25: error: expected unqualified-id before '>' token return test_type<int> (rval, loose); ^
gcc version 6.3.0 (GCC)
QMake version 3.1
Using Qt version 5.8.0
Dion
Hi Dion,
thanks for reporting this ... I did not test this combination yet. I'll take a look, but it's not top prio currently. First thing is to get the pymod branch running on MSVC.
I encountered the same problem while trying to build klayout v0.26 on RHEL6.2/7.4, with python module enable and 64bit coordinate options.
If python module is disabled, it passed with 64bit coordinate enabled.
If 64bit coordinate is disabled, it passed with python module enabled.
I tried several building environments and didn't help.
gcc v5.2.1 / v7.3.1 / v8.2.1
python v2.6 / v3.6 / v3.6.5
These building environments could be used to successfully build klayout v0.25.9
Best Regards,
chhung
Hi chhung,
thanks for mentioning this. To be honest, this combination is lacking in my build suite.
I think the problem is solved by patching line 145 of pyaConvert.h from
to
Let me know if this does the trick. I'll patch this in the sources then.
I modified the pyaConvert.h and rebuild it, however got the following error, tried to switch python version from v2.6 to v3.6.5 didn't fix.
Best Regards,
chhung
Hi chhung,
I'm sorry, my mistake. I think the correct patch is:
(note the additonal "()").
I'll try to set up a build with 64bit too, but I'm already reaching a limit of manageable builds.
I modified the code as your comment, the original error was gone, however it shows undefined reference error now. Is it an issue of our building environment ?
Then I switched the Python version from system default v2.6.6 to v3.6.3, however got the same error.
Really appreciate your replying.
Best Regards,
chhung
Hi chhung,
looks like I have to set up a similar environment myself. Sorry for guessing ... I'll keep you posted.
Hi chhung,
I was able to build successfully on Ubuntu-18. For my final patches see https://github.com/KLayout/klayout/pull/373/files
With the final patches, I am able to build klayout v0.26 on RHEL6.2 now.
Build environment:
Really appreciate your kindly help~
Best Regards,
chhung
Very good ... I'll merge the patch and close the ticket!
