Hi Matthias-
The line below works w/o issues on Klayout 0.25.4 & QT 5.6.2
However, on Klayout 0.24.10 & QT 4.8.2 I get "Invalid number of arguments (got 1, expected 0) in Qt_QFlags_WindowType.new"
What is the reason for that? What is the right way to put it so it'll work on both versions?
self.setWindowFlags(pya.Qt_QFlags_WindowType(12))
Hi mikamar,
please use 0.25.x which has this issue fixed. It's not related to Qt5 or 4, it's a problem in 0.24.x.
And once you start using 0.25.x (0.25.4 is fine, but 0.25.5 is better), you should use the symbolic constants like you would do in C++:
Thank you!
