While I have been drawing GDS using the Ruby code successfully for a while, this is the first time I am trying to manipulate existing GDS by opening the existing file and manipulating the cells. After struggling for a couple days, I am realizing that I do not quite understand the format of the "shape" I am trying to manipulate and hence would like to request some help.
I read the documentation below but am still struggling:
https://klayout.de/doc-qt4/code/class_Shape.html
The GDS is structured as:
TOPCELL
Hence I open the GDS and select the TOPCELL with "Show As New Top" and try to run the code below. Each CELLxx has shapes only on one layer (0,0). After transformations, I wanted the shapes on (1,0) layer.
Any help/pointers would be most appreciated.
Vikas
module MyMacro
include RBA
lv = Application.instance.main_window.current_view
top_cell_idx = lv.active_cellview.cell.cell_index
top_cell_name = ly.cell(top_cell_idx).name
ly.dbu = 0.001
dxf = ly.layer(RBA::LayerInfo::new(0, 0))
wg0 = ly.layer(RBA::LayerInfo::new(1, 0))
ly.each_cell do |cell|
next if cell.name == top_cell_name
cell_name = ly.cell_name(cell.cell_index)
si = ly.begin_shapes(ly.cell_by_name(cell_name), 0)
while !si.at_end?
# for each shape here, I would like to size each shape, move to a new layer and rotate by 90 degrees
# not necessarily in that order as long as all transformations are done by the end
# I tried various options including the line below but get an error
# Should I be transferring each shape to a hull and then do the transformations??
# si_hull = si.shape
# poly1 = RBA::Trans::new(2, false, 0, 0).trans(si_hull)
# cell.shapes(wg0).insert(poly1)
# OR
# Performing transformations directly on the individual shapes??
# si.shape.transform(RBA::Trans::R90.trans(RBA::Point::new(0, 0)))
# Please note that I want to write these manipulated shapes back in the same cell and delete the old shapes
si.next
lv.add_missing_layers
lv.select_cell(cell.cell_index, 0)
lv.zoom_fit
Hi All,
Any pointers or examples on the usage of the "shape" class would be much appreciated?
Vikas
Hi All,
I was finally able to figure this one out. I am writing this in case someone needs this in future. Below is the code I added in the loop. It assigns each shape in the cell to poly1 iteratively, sizes the shape by 6µm, does a Boolean and then inserts the shape poly on the layer 1 (defined as "wg0" above).
Other transformations can be added as appropriate.
Enjoy!
Vikas
Hi Vikas,
sorry for the late reply and for sharing the code!
You can also achieve this without a loop using RBA::Region objects. Region objects can cover all shapes from a layer. Basically you can write:
I assume you want to translate "dxf" to "wg0".
One more remark:
would take the shapes from layer index 0 - this is undefined. You should either use "dxf" or "wg0" which is the index of the layer defined by these variables.
Thanks Matthias! No worries about the delayed response. I am always looking to make the code more efficient and so the pointers are most appreciated!
Vikas
