Startup Options
edited October 2009 in General
Is there a way to set the application so it starts:
1) Displaying Full Hierarchy by default.
2) Without the Select/Move/Ruler toolbar showing across the top ... it take up a lot of window space.
Thanks.
  • edited October 2009
    Hi kuser,
    For the first request there is a solution: on the "Misc" page in the Setup dialog, check the "Select all hierarchy levels" checkbox in the "On Cell Change" group. I admit it's somewhat hidden ..
    For the second request, there is no simple solution currently. It is possible to remove all icons from the toolbar with a Ruby script which effectively should collapse the toolbar. In earlier Qt versions the dock management did not work well, so I fixed the location of the toolbar. I'll check if Qt provides a nice option in between so the toolbar can be collapsed if necessary.
  • JayJay
    edited November -1
    0.19.1 seems to work well for both the above.
