I am having trouble with a few functions in the processing script. When I try to use the following two functions, there will be an error. I was able to use other functions such as size, rsize, and the Boolean operations.
E.g., I created a processing script that only include the following line,
input("210/0").shift(1,0).output("210/1")
It gave an error saying that "Ambiguous overload variants - multiple method declarations match arguments." And I got the same error when I use the rotate function.
Do you know what was the issue?
Oscar
Hi Oscar,
please, please, please .... use Markdown to format your code! Put a line with triple backticks before and after the code.
The correct way of writing this is
