Hi Matthias, we're in the process of migrating our existing Ruby scripts to the latest KLayout version.
I just came across something that I didn't expect and wanted to check with you whether that's intentional or a bug:
RBA::Trans.new(1000,6610).trans(RBA::Trans.new(780,-3670).disp)
While I don't care so much about the type of the resulting object, I would've expected the resulting coordinates to be the same.
Reading the API documentation, I realise Trans.disp was changed to return a Vector instead of a Point and also support for Vector inputs was added to the Trans.trans method.
I find the 0.25.8 result particularly puzzling as it appears to be simply (a copy of?) the 2nd Trans instance at 780,-3670.
Ideally, I'd like the scripts to be compatible with both KLayout versions, is there an alternative way to code what version 0.24.10 does, so it works the same in 0.25.8?
I see I need to explain the concept here. The main difference between 0.25.x and 0.24.10 was a cleaner type system of geometrical primitive types.
One concept is that of vector vs. point (see https://www.klayout.de/doc-qt4/programming/geometry_api.html#h2-43 ).
In short, a point in an absolute location in 2d cartesian space and a vector connects two points. So:
A major difference between points and vectors is the transformation behaviour:
The reasoning is that with this definition the following intuitive equivalence is true:
because the displacements cancel.
As the "disp" part of the transformation is a vector, it will behave differently with 0.25 than with 0.24.
These are ways to achieve your desired behaviour in a portable way:
Hi Matthias, thanks for the explanation and the documentation link. The following section cleared up my question about why the vector in my example wasn't transformed:
Also thanks for the code examples. To keep my scripts as close to the original as possible, I used the following variant:
This actually simplified the original code and made the intention more clear. Great!
Christian
