Hello Matthias,
I recently tried to the following builds for klayout version 21.13:
first build:
[root@thor klayout-0.21.13]# ./build.sh -qtbin /usr/lib64/qt4/bin -qtinc /usr/include/Qt -qtlib /usr/lib64/at-3.3/lib
Qt installation directory is /usr/lib64/at-3.3/lib (lib), /usr/lib64/qt4/bin (tools) and /usr/include/Qt (includes)
Ruby installation directory is (lib), (includes) and not-used (config for 1.9.x)
Platform is linux-64-gcc-release
*** ERROR: no Qt headers in /usr/include/Qt
Second Build:
[root@thor klayout-0.21.13]# ./build.sh -qtbin /usr/lib64/qt4/bin -qtinc /usr/include/QtGui -qtlib /usr/lib64/at-3.3/lib
Qt installation directory is /usr/lib64/at-3.3/lib (lib), /usr/lib64/qt4/bin (tools) and /usr/include/QtGui (includes)
*** ERROR: no Qt headers in /usr/include/QtGui
I am probably not pointing to the correct Qt header files. Can you tell me what header files I should be pointing to?
thank you
I am not familiar with RedHat myself.
From what you told, I'd first suggest to use /usr/include as the -qtinc path. Secondly, you should check where the libQt*.so (in particular libQtCore.so, libQtGui.so, libQtXml.so) libraries are located. The may be even in /usr/lib64. Use the folder which contains the libQt*.so libraries as the argument for -qtlib.
Fedora release 16 (Verne)
- Changing line 55 of klayout-0.21.19/build.sh from
QTINCLUDE="/usr/include/qt4"
to
QTINCLUDE="/usr/include/Qt"
- Changing line 213 of klayout-0.21.19/build.sh from
if [ ! -r $QTINCLUDE/QtCore/Qt ]; then
to
if [ ! -r $QTINCLUDE/QtCore ]; then
- Changing line 56 of klayout-0.21.19/build.sh from
QTBIN="/usr/bin"
to
QTBIN="/usr/lib/qt4/bin"
Hallo,
you can achieve the same using the -qbin and -qtinc options of build.sh. But hacking build.sh for that purpose is a valid option as well :-)
