Is there a way I can disable 'View -> Highlight Object Under Mouse' feature using klayoutrc? I tried to close&save KLayout while I had it already disable it by the menu, but it didn't changed something on the configuration file (Note: I tried it with clean start of KLayout with no flags passed, e.g. -t, -c, etc).
Thanks in advance,
Chris
Hi Chris,
I can't confirm there is a bug. So maybe there is an issue with writing klayoutrc.
Could you check if you have permissions to write?
Other causes may be:
You were right about $KLAYOUT_HOME, thanks.
Chris
