Red Hat Enterprise 6.0 KLayout Build
edited November 2011 in KLayout Support
Hello Matthias,
I am experiencing some difficultly building Klayout in RHE6.0 64 bit version. The reason is the Qt libraries are in different places than previous versions of RHE.
some gcc files are located: usr/lib/gcc/x86_64-redhat-linux/4.4.5/
and additional files are placed:
/usr/libexec/gcc/x86_64-redhat-linux/4.4.5/
Please note:
-qtbin /usr/lib64/qt4/bin/ (this is same as RHE 5.3)
The Qt include files are not located under /usr/lib64/qt4/include/
However, I did find several Qt include files under /usr/include/:
Qt, Qt3Support, QtAssistant, Qtcore, QtDBuss, QtDesigner, QtGui, QtHelp, QtMultimedia, QtNetwork, GtOpenGL, QtScript, QtScriptTools, QtSql, QtSvg, QtTest, QtUiTools, AtXml, QtXmlPattens
The Qt lib files are not located under /usr/lib64/qt4/lib64/ . However, there exist lib files under /usr/lib64/qt03.3/lib/ or are missing. I did install every QT package available. I noticed RH5.3 32 bit has qt3 library files under the Qt4 installation directory.
Can you suggest the best way to build Klayout for me?
thank you
Rosario
  • edited 4:54PM
    hello Matthias,
    Thanks for your earlier suggestions. I found the Qtlib files directly under /usr/lib64, in fact several versions, for example libQtcore.so:
    libQtCore.so
    libQtCore.so.4
    libQtCore.so.4.6
    libQtCore.so.4.6.2
    If this is a problem I could move those libQt files to a separate directory under /usr/lib64 and point to them.
    I am still having problems with the build:
    [root@thor klayout-0.21.13]# ls -l
    total 84
    -rw-r--r--. 1 1000 1000 2772 Sep 19 11:50 BUILD
    -rwxr-xr-x. 1 1000 1000 8269 Sep 19 11:50 build.sh
    drwxr-xr-x. 2 1000 1000 4096 Sep 19 11:50 config
    -rw-r--r--. 1 1000 1000 491 Sep 19 11:50 CONTRIB
    -rw-r--r--. 1 1000 1000 15146 Sep 19 11:50 LICENSE
    drwxr-xr-x. 3 1000 1000 36864 Sep 19 11:50 src
    drwxr-xr-x. 3 root root 4096 Nov 22 14:22 Technical
    drwxr-xr-x. 8 1000 1000 4096 Sep 19 11:50 testdata
    [root@thor klayout-0.21.13]# ^[[C
    bash: : command not found
    [root@thor klayout-0.21.13]# ./build.sh -qtbin /usr/lib64/qt4/bin -qtinc /usr/include -qtlib /usr/lib64
    Qt installation directory is /usr/lib64 (lib), /usr/lib64/qt4/bin (tools) and /usr/include (includes)
    Ruby installation directory is (lib), (includes) and not-used (config for 1.9.x)
    Platform is linux-64-gcc-release
    ./build.sh: line 266: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile: No such file or directory
    ./build.sh: line 267: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile: No such file or directory
    ./build.sh: line 268: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile: No such file or directory
    ./build.sh: line 269: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile: No such file or directory
    ./build.sh: line 270: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile: No such file or directory
    cp: target `Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile.conf' is not a directory
    ./build.sh: line 274: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/main/Makefile: No such file or directory
    ./build.sh: line 275: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/main/Makefile: No such file or directory
    ./build.sh: line 276: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/main/Makefile: No such file or directory
    ./build.sh: line 277: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/main/Makefile: No such file or directory
    ./build.sh: line 278: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/main/Makefile: No such file or directory
    ./build.sh: line 279: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/main/Makefile: No such file or directory
    ./build.sh: line 297: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile.env: No such file or directory
    ./build.sh: line 298: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile.env: No such file or directory
    ./build.sh: line 299: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile.env: No such file or directory
    ./build.sh: line 300: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile.env: No such file or directory
    ./build.sh: line 301: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile.env: No such file or directory
    ./build.sh: line 302: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile.env: No such file or directory
    ./build.sh: line 303: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile.env: No such file or directory
    ./build.sh: line 304: /root/Desktop/Thor Technical/klayout-0.21.13/build.linux-64-gcc-release/Makefile.env: No such file or directory
    Building plugins:
    Running build ..
    gmake
    gmake: *** No rule to make target `all'. Stop.
    Do you think the problem could be an incomplete gcc compiler? There are three versions in the /usr/include/c++ directory: 3.4.6, 4.4.4, 4.4.5 and have added all available options.
  • edited 4:54PM
    Hi Rosario,
    you don't need to move any libraries - it should work without that.
    I guess the problem you encountered are related to the blank in the path /root/Desktop/Thor Technical/...
    Can you try building in a folder that does not have a blank in the path?
  • edited 4:54PM
    Hello Matthias,
    Yes, that was the problem. Linux in general I find dislikes two word names with spaces. I copied the build commands right out of the build instructions you provided and the script ran perfectly.
    thank you
