What is proper way to move set of layers (change their order) in Python? Or re-arrange cellviews order because in I need to move all layers belonging to particular cellview.
the solution depends on what you want to achieve.
In any case I'd recommend to use the LayerIterator concept. "LayoutView#each_layer" isn't entirely stable for iterating while deleting (see https://github.com/KLayout/klayout/issues/368).
Here is some sample code that moves all layer with even GDS layer numbers to the end:
Hi, Matthias!
Thank you for help! Similar code pattern (I used active_cellview.index() as criteria) solved my problem!
