pya.Cursor.None bug?
I was looking at the list of available functions to pya.Cursor
I noticed "None" was part of it and I assume it should make no cursor visible however, there is an issue when compiling (pya.Cursor.None),
It seems to be a conflict with standard python empty variable?
  • Still adding a piece of code:
    pya.Cursor.Cross #compile without issue
    pya.Cursor.None #syntax error
  • Answering partially my own question:
    to make the Cursor not visible we can use
    pya.Cursor.Blank
    Why 'None' is listed in the available functions to pya.Cursor is not so clear however
  • Hi jonathan,
    "None" was intended to reset the cursor to the application default, not make it invisible. But for Python, "None" is a reserved word, so this is not available :-(
    I'll give a different name (i.e. "Default") and leave "None" only for backward compatibility. Here is the ticket: https://github.com/KLayout/klayout/issues/386
